I want to replace the jet engine that is the fx-8320 stock cooler.
What sort of cooling should I go for?
I want to be able to get a decent overclock . Any suggestions?
212 evo, youll be able to oc it too.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/383079-what-cpu-cooler/#findComment-5172336
212 evo. For FX 6xxx/8xxx CPUs a 212 EVO lets you overclock easily. My max temp on my FX-6300 1.4v 4.2ghz is 50 degrees celcius, with a 27DC room temp
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/383079-what-cpu-cooler/#findComment-5172369
Don't have the measurements but I have a corsair 230t. I'm not sure if I want to go air or all in one water.
i found online you can fit coolers up to 160mm in that case. the CM hyper 212 evo is 159mm tall so it should fit! :P
if you want to go watercooled a corsair H60 or H80 should be more than enough too!
https://linustechtips.com/topic/383079-what-cpu-cooler/#findComment-5172397
