So I have had a lot of issues lately with my PC.
Drivers failing, Windows failing to scan for updates right, Etc,
I'm up to my knees in dead failing programs and issues and I'm sick of it and am just going to re install my windows.
a few questions before I do..
1. Is there any better drivers than the ones for your devices and what about the ones provided by Windows?  Is there a good driver tool that can scan and update for proper drivers and the best ones for you?
2. Windows 7, 8.1 , or 10 TP ? I don't care much and while Windows 8.1 gives some perks I miss 7 and it's simplicity.  However I did have issues on 7 and ultimately idk.  DX12 is due and I don't think it will be for 7 and TP looks quite nice.
3. I rarely actually boot my windows system leaving it in sleep a lot, and have a 120GB Samsung 840 Evo, should I use this drive for a few games I really like, or keep it as a boot drive and use like a small 250GB HDD I have for my windows?
4. Some games skyrim especially run odly slow and stutter a lot. While I do have a 15GB texture pack installed for it, It's all 2K textures and I have a 970 EVGA SC with an extra 100mhz OC.  my i5 is also OC to 4.4GHz any clue as to why I get a stupid 37-47FPS normal in whiterun ?  And with the game un modded / fixed it's even worse going haywire from 27-53FPs
5. Any extra tips for re installing my system? And should I erase ALL my data on all my drives, Or only my main windows drive?
System Specs
Case: NZXT Phantom 410 Black
MB: MSI G55-Z97 SLI
GPU: EVGA SC GTX 970
CPU: Intel i5-4690K
PSU: EVGA Super Nova NEX Gold 650
RAM: 1600MHz DDR3 2x4GB crucial + 1x2GB Unknown brand
Drive 0: Samsung SSD 840 Evo 120GB
Drive 1: WD Black 1TB
Drive 2: WD Blue 500GB
Drive 3: Seagate Barracuda 2TB
Drive 4: 320GB Seagate Momentus Thin
Drive 5: USB 5'25" bay All in one.
Drive 6: DVD Reader cause of games like GTAV and Wolfenstein.
https://linustechtips.com/topic/382568-pc-issues-and-re-installing/
generally you download the drivers from the hardware manufactuers site OR the chipsets manufactueres website..I usually use the chipsets manufacter cause they are always newest..I also use stationdrivers...for even newer drivers
personally hate 8..unless I modify its gui to be more like 7....it is faster..no question there..but not by much
ssd as boot drive....hdd as storage drive
you got some weird problem here....solve it after you clean install...if the clean install doesn't fix it (It should)
backup all the important stuff..and stuff that takes alot of time to config
just erase the windows boot drive...nothing else
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
