This is my first PC I am planning to build, and before ordering, I just want to check that everything fits together and works properly.
I have already done a few checks eg GPU and CPU cooler compatibility, but if anybody could point out if 1 component isn't compatible with another, it would be greatly appreciated
http://uk.pcpartpicker.com/p/xBWpLk
https://linustechtips.com/topic/382154-will-it-fit-together/
should be fine:-)
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/382154-will-it-fit-together/#findComment-5160171
Crucial SSD's are very expensive where I live. Any other suggestions?
what country?
oopsie, "uk.pcpartpicker.com"
can't you just buy from internet?
Storage: Crucial BX100 120GB 2.5" Solid State Drive  (£49.54 @ CCL Computers)
Total: £49.54
Generated by PCPartPicker 2015-06-07 15:10 BST+0100
9 pounds more...
https://linustechtips.com/topic/382154-will-it-fit-together/#findComment-5160206
