It would be cheaper if you would have all the tools already and if you dont count all the trial and error
but it isnt, if its your 1./2./3. time it might work...
try to look into the bitfenix alchemy extensions or visit/contact @Icemodz or @modguru
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/381963-custom-cable-sleeving/#findComment-5158471
Hi @Mac10897
We can both make you custom made extensions or PSU cables or sell you supplies to make them yourself.
As @X_Rated_Box said (Thank you btw) you can contact us for more specific pricing.
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
https://linustechtips.com/topic/381963-custom-cable-sleeving/#findComment-5158697
The other day  i was going to buy a set of custom cable sleeve but i found out it was much cheaper just doing them myself. So i was wondering if there was any website that have all the parts i need or just a kit that i could buy
As said unless you plan to do a fair amount of sleeving the tools will cost you a fair bit. If you do want to do custom sleeving yourelf you can check out places like LutroCustoms which should have you covered for everything, another is Icemodz.
https://linustechtips.com/topic/381963-custom-cable-sleeving/#findComment-5162940
