I bought a EXP Graphic Display Adapter a week or so ago.
It came with everything except this 24 to 8 cable... I've searched all over the net to find and buy one, but to no avail.
Possibly it has a another name, or maybe is a custom crafted cable? I would really appreciate it if someone could point me in the right direction.. please help me.
https://linustechtips.com/topic/381710-help-weird-psu-cable/
Looks custom crafted to me as ive never seen one of those before. If i may ask, what would that tool be called? I am in desperate need of one.
https://linustechtips.com/topic/381710-help-weird-psu-cable/#findComment-5158890
What tool? to make the connections that go into the connectors? that's a crimp tool or crimping tool.
//edit:
http://www.aliexpress.com/item/ATX-to-EXP-GDC-20Pin-CPU-4Pin-to-EXP-GDC-8Pin-Power-Supply-Adapter-Converter-Cable/1904471231.html
search something like "EXP Graphic Display Adapter atx cable" and you'll find some results.
https://linustechtips.com/topic/381710-help-weird-psu-cable/#findComment-5159096
