Hey guys I've just ordered myself pretty much every thing I need to build myself a mini ITX 4K gaming machine in a corsair 250D. I was just wanting some tips on cable management and want not. Any advice would be appreciated. Photos will come as soon as it all arrives,
Specs for it are:
Intel I5 4690k
Gigabyte GTX980TI
16 GB Corsair Vengeance 1866 DDR3
Galax Gamer 240gb SSD
Gigabyte Gaming 5 mini ITX wifi motherboard
Corsair RM750 FUlly modular power supplie
Corsair 100i GTX Closed loop water cooler
I might have missed a few things out but il update if so.
Cheers guys :)
https://linustechtips.com/topic/381613-mini-itx-980ti-build/
750Watt is way more than you need for that build also never even heard of a galax gamers ssd.. bound to be something else re-branded.
But then if you've already ordered it it's probably too late to change..
As for cable management, there is lots of room in the bottom of that case around the PSU, should be a breeze
GL with the build.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/381613-mini-itx-980ti-build/#findComment-5154155
