EDIT: nvm, I had to re-read that.
The 960 will last longer for future games.
Get the i5 4460. On newegg and Amazon, it's cheaper and performs better.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/381257-how-much-watts-do-i-need/#findComment-5149975
https://linustechtips.com/topic/381257-how-much-watts-do-i-need/#findComment-5149978
But he is using both a 750 ti and a 960 so more might be good.
:)xD9_9:D:PB|
https://linustechtips.com/topic/381257-how-much-watts-do-i-need/#findComment-5149980
Why would you want him to spend more on a lesser wattage powersupply? Even worse, Corsair!
blackshades on
https://linustechtips.com/topic/381257-how-much-watts-do-i-need/#findComment-5149987
The EVGA you linked is not a good unit. Only their G2/B2/GS and so on are good, the linked one is made by HEC and is very meh
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/381257-how-much-watts-do-i-need/#findComment-5151113
