i got a asus z97 pro wifi, and when i boot, not everytime, it will hang on post code 64 for up to 5 mins before booting into windows, it may restart itself once or do other things, why is this? ill try get a video but when i go to try it boots normally
The ASUS motherboard manual lists all post codes and what they mean. A code 64 is normally when its trying to identify a USB storage device and work out if its bootable, though without knowing your hardware I can't be sure.
Please notice the posting guidelines when asking for help http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5168865
is there a way i can disable that?
sorry about the specs
Motherboard Asus Z97-PRO (WiFi-AC)
CPU Intel Core i7-4790K Processor
RAM Crucial Ballistix Tactical Tracer 8GB Kit
Graphic Card ASUS STRIX GTX970
Power Supply Corsair HX750i
SSD Samsung 840 EVO 120GB RAID 0
O/S – Windows 7 64bit
here is a vid too
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5173882
This talks about the post 64 error code:http://rog.asus.com/forum/showthread.php?11723-Maximus-Gene-Z-hangs-on-debug-code-64
this talks about a possible solution:http://vip.asus.com/forum/view.aspx?id=20120116084934678&board_id=1&model=Maximus+IV+GENE-Z&page=1&SLanguage=en-us
solution may be for a not so severe hang as you, but one never the less.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5173959
If there is an option to disable boot from USB I'd do that personally, I tend to enable USB boot only when I want it because I have a really bad habit of leaving mem sticks in my PC. My work PC you can't turn it off and USB is always higher priority than HDD so if you leave a usb device in when you hit the power it won't boot :(
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5175447
ill look for it, why does it not happen all the time though? sometimes i go 10 boot ups and its fine. also sometimes it takes 2 mins other times it takes 5 mins
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5175574
what would it be under? ive had a look cant seem to find anything...
im sure there has to be something, shouldnt take 5 mins to boot a pc up
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5228464
Boot priority.
You normally have three options
Option one normally defaults to a USB / DVD drive
Option two is HDD / SSD
Option three is blank.
It should be
Option one SSD / HDD
Option two blank
Option three blank
Then go into specific drive boot priority's
You will have one for the HDD / SSD. The boot should be the only one picked.
The rest leave blank.
That's how it should always be. If you ever need to boot from a USB / DVD or anything else because you're formatting or dual booting then hold F8 when you push the power button. You will get a window asking what you want to boot from.
Unplug all USBs when you're booting up.
It's not a race to the bottom.
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5229953
Boot priority.
It should be
Option two blank
Option three blank
second boot i normally leave on CD, what it was but ill disable it
only got ssd enabled now
no usb have ever been installed when i boot, only the mouse keyboard ect
so ill see how it goes and ill report back
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5233047
  • 2 weeks later...
Boot priority.
It should be
Option two blank
Option three blank
just happened again then so, seems its some thing else
any ideas?
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5311328
anyone else able to help me out?
Okay shooting into the dark now,
You've done boot device priority.
Remove front panel USBs, and Keyboard & mouse (you can plug the KB back in later on as it's not PS2)
Remove the SSD/HDD. Just unplug the sata power cables. (To see if it still hangs)
Update bios within the bios (not windows).
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5326493
i cant do this....
it might hang once in 40 boots
if it hangs every time then yea i could do
bios is updated
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5326826
i cant do this....
bios is updated
Ah, so it's very rare?
Have you got a different SSD/HDD you can boot off that ain't already in the system?
Or, if you want to, even though it will also annoy me, unplug the drive before every boot for a month or so. If it doesn't hang then plug the drive back in and press Alt + Ctrl + Delete. (it will restart the system) Or you could just allow it to go into bios. Most motherboards will now go into bios automatically if no boot device is found. When in bios just press ESC to boot normally after you've plugged your drives back in.
That is a very annoying way to find the problem, but I do think it's a boot problem. There's some kind of incompatibility somewhere.
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5326859
yer its rare
since its hanging on post 64, that must mean something
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5327213
after post 64 sometimes it restarts and today it was also hanging on post 'AE'
Ok after reading your manual (I'm guessing it's correct) http://images10.newegg.com/UploadFilesForNewegg/itemintelligence/ASUS/E9062_Z97_PRO1401383332300.pdf
Error code 64 lies within an error named "cpu dxe initialization" which seems to relate to the CPU accessing memory. Or something like that.
Error code AE is an error named "legacy boot event" which after a 3.2345345ms of Goggling (so could be wrong) has something related to not finding a boot device.
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5335735
so any ways to fix it?
https://linustechtips.com/topic/380803-hanging-on-post-code/#findComment-5336239
