Mobo not recognizing ethernet
Did you install the Ethernet drivers form the official website? Is the Ethernet controller recognized in Device manager?
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
I think it's a phsyical issue, as other computers have worked. No lights show up and it doesnt give the same click like usual? How do I fix this?
Mobo: Asrock 960gm
Did you try installing it from the driver CD? Since u can't download it from the website?
That username...
Of course. The problem was phsyical. Was just a stiff connection.
Again, Is the Ethernet controller recognized in Device manager?
If it is recognized there it is not a physical issue. Also what do you mean when you say "stiff connection"?
So you are saying that you installed the drivers from the website without the Ethernet working?
Why do you find that weird? There are flash drives and s###.
CPU: Ryzen 3 3600 | GPU: Gigabite GTX 1660 super | Motherboard: MSI Mortar MAX | RAM: G Skill Trident Z 3200 (2x8GB) | Case: Cooler Master Q300L | Storage: Samsung 970 EVO 250G + Samsung 860 Evo 1TB | PSU: Corsair RM650x | Displays: LG 27'' G-Sync compatible 144hz 1080p | Cooling: NH U12S black | Keyboard: Logitech G512 carbon | Mouse: Logitech g900
