Need Mid/Full tower ATX Case
Go to solution Solved by N3D9ed,
I'd recommend Fractal's Arc Midi R2 if you're looking for a case that has good air flow as well. The windowed side panel is large enough and it is tinted so not sure if you'd like that or not.
I need a case with a well constructed non-scratch side pannel. The side pannel must be large to show the internals, any recommendations?
Oh and it needs 2 drive bays minimum.
fractal define r5 with side window maybe?
askdjfasdf
If you regard my facts as wrong, feel free to rectify it.
If you regard my opinions as wrong, feel free to ignore it.
