Hey guys I want to know want you think of my build:
http://pcpartpicker.com/p/tfw43C
looks good actually. but unless you video edit i recommend getting an i5 and maybe spending more on the motherboard but it looks fine otherwise.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/380609-graphics-card-help/#findComment-5142549
What would be better for this build: http://pcpartpicker.com/p/KBkQvK
2 way crossfire 290x's or
1 gtx 980 ti overclocked 15%
Its for a friend (a.k.a MattTheYoungBuilder)
If you have a choice always go for the higher power single card over the two lesser cards. You can always get a second one later on down the rode.
Current parts for new build. Case: CM Haf X full tower | MB: Asus Rampage V Extreme | Storage: WD 1TB HDD & Samsung 850 Evo | PSU: EVGA Supernova 750 G2 | Display: AOC G2460PQU | Cooling: Corsair H100i GTX | Keyboard: Corsair K70 RGB | Mouse: Razor Deathadder Chroma
Still need CPU, RAM, and GPU
https://linustechtips.com/topic/380609-graphics-card-help/#findComment-5143324
