Build updated
Go to solution Solved by Lotus,
http://pcpartpicker.com/p/9Ptfcf
I would get a different HDD as the hitachi ones don't have a good track record. Other than that it looks phenomenal.
I will order my build tomorrow any changes
http://pcpartpicker.com/p/7K6tyc
PCPartPicker part list: http://pcpartpicker.com/p/7K6tyc
Price breakdown by merchant: http://pcpartpicker.com/p/7K6tyc/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($99.00 @ Amazon)
Motherboard: Asus Z97-E ATX LGA1150 Motherboard  ($88.24 @ Newegg)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($109.99 @ Amazon)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($42.50 @ Amazon)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card (2-Way SLI)  ($649.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($109.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($114.99 @ Newegg)
Monitor: Asus PB278Q 60Hz 27.0" Monitor  ($424.99 @ NCIX US)
Other: Xbox One controller ($50.00)
Other: Gta 5 ($50.00)
Total: $2719.67
Generated by PCPartPicker 2015-06-04 19:40 EDT-0400
"Winter is coming"
    -Ned Stark
https://linustechtips.com/topic/380506-build-updated/
Plox post a link that works and I'll tell you haha.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/380506-build-updated/#findComment-5140800
Link not working so I just posted the text
ehh its working now, you might have been editing it at the moment.
Anyways just my two cents, unless you really want it, there isn't any need to go full tower, mid works just as well and is a tiny bit cheaper.
Also that HDD is scary as fuck. with SLI 980s you really should be running SSD's (otherwise imho you are doing yourself a disservice.)
https://linustechtips.com/topic/380506-build-updated/#findComment-5140950
Very nice build, i would consider waiting for the new amd cards, but that just me. Looks amazing though when it is done definitely provide some benchmarks! Also why didn't you go with the i7 5820k and ddr4 though?
I run my own indie game company called Color Dragon Studios where we are currently making a 2d platformer game called Small Earth.
https://linustechtips.com/topic/380506-build-updated/#findComment-5140975
The HDD is for my old build so I can give it to my brother, I have 4TB and a 500gb SSD already purchased
"Winter is coming"
    -Ned Stark
https://linustechtips.com/topic/380506-build-updated/#findComment-5141023
I will mostly be using this build for gaming so I don't need the extra cores and also because of tight budget
"Winter is coming"
    -Ned Stark
https://linustechtips.com/topic/380506-build-updated/#findComment-5141040
I would also recommend staying down on z97. Single core is the more important thing for gaming for as long as games don't scale for shit beyond 4 (really 3) cores, and the 4790k is currently your best bet for that.
The rest is cool.
https://linustechtips.com/topic/380506-build-updated/#findComment-5141072
Ok that make more since then still pretty awesome!
https://linustechtips.com/topic/380506-build-updated/#findComment-5141147
get a better monitor like PG278q or XB270hu
Edit: saw you said you had an ssd
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/380506-build-updated/#findComment-5141183
Get SSD - NVM
Magical Pineapples
https://linustechtips.com/topic/380506-build-updated/#findComment-5141238
