Hello everyone! :)
If i use two connections 60/4 on one and 45/5 on another, where does this not work? I mean, just use one connection only. If i upload something to Google drive it says it's uploading at around 6Mbps.
If i do a Speedtest it shows around 10Mbps up...
Thanks!
EDIT: i am using this router to combine them
https://linustechtips.com/topic/380145-where-does-combing-connections-not-work/
Hello everyone! :)
Thanks!
Barnacules does it with 3 somehow.
The thing to remember with Dual WAN is you still will not get speeds faster than the fastest connection. Load Balancing will only balance different clients or connections/streams between each connection. Dual WAN is great for Redundancy and distributing many users over multiple connections. You will however not get any faster speeds.
