Yeah I'd get a EVGA SuperNova power supply. ( Has G2 on the box or in the name) <-- ( those are reliable PSUs) If you can. Otherwise fine. It's gotta suck being in AU, In the U.S. this would get you a 4690k and a GTX 970
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/379774-solid-build/#findComment-5131769
Is this a decent build? What would you change without spending extra money? (Prices are in AU)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($246.00 @ PCCaseGear)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($109.00 @ CPL Online)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory ($89.00 @ PCCaseGear)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($70.00 @ Centre Com)
Video Card: Sapphire Radeon R9 280X 3GB Vapor-X Video Card ($299.00)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case ($95.00 @ CPL Online)
Power Supply: be quiet! 600W 80+ Bronze Certified ATX Power Supply ($89.00)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($125.00 @ Mwave Australia)
Total: $1122.00
Generated by PCPartPicker 2015-06-04 08:37 AEST+1000
Hey Gooplez,
Adding a SSD to your system would dramatically improve the build's performance and responsiveness. It does increase the budget, but it reduces the loading and boot times of the build, increases the transfer speeds and makes the computer much more snappier.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/379774-solid-build/#findComment-5134962
