One side is USB type C the oter type A. So we can use everywhere
Although revealed at computex, it looks like it has been available for a while from amazon for  36.99gbp
Buy here: http://www.amazon.co.uk/SanDisk-SDDDC-032G-G46-Ultra-Flash-Connector/dp/B00V62XBY8
Sourcehttp://www.theverge.com/2015/6/3/8719629/sandisk-usb-c-dual-flash-drive-computex-2015
SanDisk-Dual-Flash-Drive-with-USB-Type-C
https://linustechtips.com/topic/379562-usb-drive-with-type-a-c/
No point in a 3.1 stick, the NAND on the stick won't saturate a 3.0 port for some time to come.
This is a nice way to make a stick compatible with both standards.  I'm thinking that the C-to-A or A-to-C adapter will be quite popular in the near future though.
https://linustechtips.com/topic/379562-usb-drive-with-type-a-c/#findComment-5129396
Eh, now that we have NVMe and 10Gb USB 3.1, I could see sticks saturating USB 3.1 easily in another couple years.
Software Engineer for Suncorp (Australia), Computer Tech Enthusiast, Miami University Graduate, Nerd
https://linustechtips.com/topic/379562-usb-drive-with-type-a-c/#findComment-5129441
its not 3.1 its 3.0
if you want to annoy me, then join my teamspeak server ts.benja.cc
https://linustechtips.com/topic/379562-usb-drive-with-type-a-c/#findComment-5129498
Depends, right now 1.2Gb/s (150MB/s) is extremely fast for a USB stick, so we're nowhere near the 5Gb/s cap of USB 3.0 yet.
The only thing that saturates a 3.1 port is an enclosure with SSDs in RAID.
As for NVMe, we're still some time away from that becoming small and cheap enough to be used in a USB stick.  Maybe in 2-3 years
its not 3.1 its 3.0
I'm aware of that, I was merely commenting on the 3.1-related question.  Perhaps I should have made that clearer.
https://linustechtips.com/topic/379562-usb-drive-with-type-a-c/#findComment-5129559
The only thing that saturates a 3.1 stick is an enclosure with SSDs in RAID.
uh ya, I agree. I dont know of really anything that I could see my self buying that needs faster speed then USB 3.0 let alone saturate it.
https://linustechtips.com/topic/379562-usb-drive-with-type-a-c/#findComment-5129606
Guest
