Hey guys i'm from the Philippines and i will be building my first pc very soon here is the link to all the parts I selected http://pcpartpicker.com/parts/partlist/. I would like some advice and recommendation for parts that i should change
Thank you and I hope to hear from you guys
Sorry about the link i don't know whats wrong with when you guys open it so here's some pics of the parts i selected instead .
Ok try this link http://pcpartpicker.com/user/M97/saved/ncWCmG
Ps my budget limit is 1500$
https://linustechtips.com/topic/379491-my-first-pc-build/
so you chose no parts? thats a truly silent pc
Builds:
https://linustechtips.com/topic/379491-my-first-pc-build/#findComment-5128058
That is the wrong link OP
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/379491-my-first-pc-build/#findComment-5128068
you gotta put the permalink not the URL link
like this http://pcpartpicker.com/p/x894ZL
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/379491-my-first-pc-build/#findComment-5128082
Take out the Harddrive it makes noise :D and 2tb of ssd storage should be enough for a new system
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/379491-my-first-pc-build/#findComment-5128175
