If you're only gaming then there is no need for such a high-end motherboard as you will not use the features, all you will be doing is wasting money. I would highly suggest you go with an ASRock Z77 Extreme 4 or Gigabyte GA-Z77X-UD3H for about $150, they will both offer near enough the same features and will support SLI/CrossFireX if you ever need it.
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46760
i also overclock to 4,6 i have a msi mpower z77 right now i dont like asrock or gigabyte bords i like msi and asus bords
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46768
Why are you upgrading if you already have an MPower?
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46782
Then you don't need to upgrade if you already have an MSI Z77 MPower. And there is nothing wrong with ASRock or Gigabyte boards but if you really did want MSI or ASUS then I would recommend the MSI Z77A-GD65 or ASUS P8Z77-V but seen as you have an MPower there isn't any need.
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46785
The Mpower is a fucking awesome board, why you wanna change that? I'd have bought the Mpower if it was out at the time I built my rig =P
Built it into my brothers PC tho, it pwns.
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46789
ok i was not sure if the mpower was good for gameing or not im new to this hole buliding rig stuff im buliding my first gameing pc idk someone told me that asus makes the best so thats y i went and looked at asus
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46790
i love the mpower bord only reson i was looking at asus was i was told there the best idk im just gona keep my mpower
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46794
Good decision. Besides that "Gaming"-branded stuff is usually only marketing. Don't fall for that ;P
https://linustechtips.com/topic/3793-help-on-picking-mobo/#findComment-46798
