So I've been deciding on building a custom case and figured I'd come here for a few opinions.
I currently use an old Lian Li PC-50 (Which is still a great case.), and I figured that I may possibly be able to salvage the aluminum on it depending on what I'm going to do.
So, without further ado, I'm trying to figure out a case that's unique. What I mean by unique is, for example, using a soda machine as a case, though I wouldn't do that at all. Something smaller. Suitcase maybe? I could pick it up and take it with me anywhere I went. I could also hook up a monitor inside the suitcase so it'd act as a laptop in a way. (Though I'm quite sure the metal detectors in airports would go nuts. I can only imagine this scene.) Honestly, I want something unique. I could just go with a regular PC case, but modify it to look different, which I like the idea of.
Any opinions or suggestions are appreciated! Honestly, let's have some fun with this one.
PC and Peripherals:
Intel Core i3 4150 @3.5GHz - ASRock H97M Anniversary - Kingston Fury HyperX Black 8GB DDR3 @1866MHz - Gigabyte GeForce GTX 960 G1 Gaming 2GB GDDR5 - EVGA 500W 80+ Certified - WD Caviar Blue 1TB - WD Caviar Blue 160GB - Lian Li PC-50 - Linux Ubuntu 14.04.3 LTS - Acer P221w 21.5" 1680x1050 60Hz - Kingston Fury HyperX Clouds - Razer Deathadder 3.5G - CM Storm Quickfire Rapid w/ Cherry MX Blues
https://linustechtips.com/topic/379204-custom-case-suggestions/
I have an idea for you, you could try building a pc in an old oscilloscope chassis. Maybe then have a lcd where the screen used to be and use that for monitoring temps
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/379204-custom-case-suggestions/#findComment-5124178
I actually really like that idea.
PC and Peripherals:
https://linustechtips.com/topic/379204-custom-case-suggestions/#findComment-5124209
Thats actually brilliant... But where would you find one big enough to fit a computer inside? The only ones I have seen are like 10" L 5" W and 5" H or something like that. Unless you could find some industrial sized one.
https://linustechtips.com/topic/379204-custom-case-suggestions/#findComment-5127549
