Question about Intel CPU Manufacturing
Go to solution Solved by ProKoN,
I was talking only in terms of desktops :).  I like your avatar, bye the way.
Thanks, right back at ya.
IBM is the shizzle. I do part time work for them on a enterprise level.
All real techs roll with a thinkpad in hand :)
Hey guys, just a quick question here. I'm reading about how Intel manufactures and bins CPUs, but there's one thing I don't understand.
As I understand it, CPUs that don't perform as well are sold as lower end. For example, a CPU designed to be an i7 might not be up to spec and is therefore sold as an i3 or whatever at a lower clock. If this is true, does that mean that they design all of their CPUs to be i7s, but only a few make it out? Or do they have separate dies for each chip?
I think the reason why I'm confused is because as I understand it there is a physical difference between the different chips, different core count, different GPU, etc. Thanks!
https://linustechtips.com/topic/37905-question-about-intel-cpu-manufacturing/
About 48:00 in I brought it onto the WAN show and Linus covers it.
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
PCBudgetSolutions, watching your question is what got me thinking about all of this. I think my question is similar to what Slick said. For example, is an atom processor with 2 cores identical to, say, a xeon processor with 12 cores? That doesn't make sense to me because they have completely different chip designs, right?
Would it be a good assumption that an i7-4770K has a better chance of being a better overclocker than an i5-4670K? Or are they binned based on something that
has nothing to do with whatever part of the chip is responsible for the OC quality? I am hoping whatever chip I buy in the near future is a beast overclocker so I
am trying to determine what cpu to buy.
This is true.  All i3 CPUs are defective i7s, for example, with defective parts disabled and then they are sold off at a discount, effectively.
There are only two designs Intel has active at one time.  Their quad-core LGA 1155 design, where the i7-4770K for example is the "full" design, and the 8-core socket LGA 2011 design, with an 8-core "full" design, like Xeons.  The Extreme Edition processors are defective Xeons.
I do believe Intel has four designs active at one time. Dont forget about the mobile cpus.
Since the dual core mobile has a different package type than a quadcore mobile chip.
otherwise, well put.
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
