Hi!
I'm planning on building a new PC to replace my old msi laptop. I have been drooling over components over the last few months and have put together a build i think would fit my needs. I'm paying for this with ny hard earned money, so i would like to not spend any uneccesary momey on things i don't need. Keep in mind i'm from Norway, so some prices might differ from your american prices. Without wurther adue, here is the list of components:
AMD fx-8350
NZXT source s340 black
Corsair cx600m 600w
CM hyper 212m evo
Samsung 850 evo series 250gb
Gigabyte ga-970a-ds3p
WD red WD30efrx 64mb 3tb
Crucial ballistix sport ddr3 1600mhz cl9 2x8gb
Nvidia Gtx 780ti
I tried to go for a slightly black and red theme. I'm getting the 780ti from a friend for about 250$ so that's why i'm using that. I will be doing some light overclocking so i have gone a little over the top om the powersupply, so bare that in mind.
Thanks in advance! :)
https://linustechtips.com/topic/378966-first-build/
The CPU will bottleneck the crap out of the 780ti. Get an i5.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/378966-first-build/#findComment-5121286
Try to get a i5-4690k or if you wanna sacrifice overclocking an i5-4590
EDIT- try and out this in a PCPartPicker link also.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/378966-first-build/#findComment-5121305
https://pcpartpicker.com/user/stonehard/saved/fxXNnQ
I swapped to the i5-4690k and a new motherboard. The more power efficent i5 made it possible to downgrade the powersupply to a 500w aswell.
You will need a Z97 board for the i5 to work. The i5 can work on the Z87, but you need to do a flash bios update, Which requires a CPU like a 3670K.
https://linustechtips.com/topic/378966-first-build/#findComment-5121482
https://linustechtips.com/topic/378966-first-build/#findComment-5121513
what games will you be playing? BF4 likes 2400mhz ram
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/378966-first-build/#findComment-5121530
I would get this, the psu you chose is crap and i changed the ram since you can gain about 10 fps in bf4 with 2400mhz over 1600mhz. Also the WD Red is designed for NAS so that is unnecessary, wd green or black is you best bet
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.89 @ OutletPC)
Video Card: EVGA GeForce GTX 780 Ti 3GB Video Card  ($257.00)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Total: $1081.27
Generated by PCPartPicker 2015-06-02 17:54 EDT-0400
https://linustechtips.com/topic/378966-first-build/#findComment-5121548
Newer games like the witcher 3, and some mainstream games like csgo and lol with my friends.
I have bf4 but i haven't played it in a year. The only reason i would play it, would be to check out the fps on ultra for brag rights [emoji14]
i love bf4 :P 270h played since feb xD BTW i edited the post, please read it again ^^
https://linustechtips.com/topic/378966-first-build/#findComment-5121582
i love bf4 [emoji14] 270h played since feb xD BTW i edited the post, please read it again ^^
Still not sure if it's worth the 2400mhz RAM, but i'll consider it. For the psu and harddrive i just chose something that looked alright so i'll definetly change those.
https://linustechtips.com/topic/378966-first-build/#findComment-5121614
Still not sure if it's worth the 2400mhz RAM, but i'll consider it. For the psu and harddrive i just chose something that looked alright so i'll definitely change those.
i would have gotten 2400mhz ram if i knew the difference when i purchased the ram, but it's totally up to you
https://linustechtips.com/topic/378966-first-build/#findComment-5121646
Hi!
AMD fx-8350
Corsair cx600m 600w
CM hyper 212m evo
Nvidia Gtx 780ti
Hey steinarhansen352,
The plan looks good. The guys also gave you some good advice. I would read first what is recommended and supported in terms of frequency of the memory before deciding to go with 2400MHz.
Regarding the storage, it is a great thing to combine SSD with a HDD. WD Red drive is designed for NAS/RAID usage since it has additional features that make is more stable and safe to operate in such environments. If used in a regular desktop for simple storage, those features won't be utilized and the drive would perform like WD Green in terms of performance. I would consider swapping it for WD Green. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/378966-first-build/#findComment-5125272
Why does everybody advice an I5? The FX 8350 is not that much diffrence with an I5 4670k soo, and I have one, and if I see some benchmarks with an I5, I get the same results, (with an GTX 970) so from experiance i'd say a FX 8350, but for future upgrades and things like PCIe 3.0 i'd say an I5...  What do you guys think?
https://linustechtips.com/topic/378966-first-build/#findComment-5127508
I believe people are referring to the Single-core performance, differences in TDP, currency of the CPU itself (when it came out).
https://linustechtips.com/topic/378966-first-build/#findComment-5127644
Don't get Corsair CX, it is overpriced, underperforming and due to this, rubbish. Look at EVGA B2/G2/GS or XFX TS/XTR, Antec High Current Gamer or any Seasonic.
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/378966-first-build/#findComment-5128556
