hi all,
So I'm having a few problems with my new rig here are the specs:
Intel core 2 quad q6600 G0
Hyper 212 evo
Asus p5q deluxe
4gb ddr2 ram
R9 270X
Wd blue 1tb
Optiarc ad 7230s
Corsair spec 03,
So here is my problem, when I boot into the windows 8.1 64bit disc it comes up with a count down with some text saying "inproper boot media please insert proper media and reboot" what could this be?
https://linustechtips.com/topic/378862-first-build-help/
hi all,
Hyper 212 evo
Asus p5q deluxe
4gb ddr2 ram
R9 270X
Wd blue 1tb
Optiarc ad 7230s
Corsair spec 03,
give me some more details
Indus Monk = Indian+ Buddhist
https://linustechtips.com/topic/378862-first-build-help/#findComment-5119767
hi all,
Hyper 212 evo
Asus p5q deluxe
4gb ddr2 ram
R9 270X
Wd blue 1tb
Optiarc ad 7230s
Corsair spec 03,
Try setting default boot to UEFI
I have no idea what I'm doing
https://linustechtips.com/topic/378862-first-build-help/#findComment-5120014
hi all,
Hyper 212 evo
Asus p5q deluxe
4gb ddr2 ram
R9 270X
Wd blue 1tb
Optiarc ad 7230s
Corsair spec 03,
Hey L200fanatic,
I would reset the CMOS and then check if all the BIOS settings are properly adjusted.
By saying "booting from the Windows 8.1 x64 disk" do you mean your HDD where the OS is installed or the actual installation CD/DVD?
Also you can take that WD Blue to an already working system and run a diagnostic tool on it to make sure it is functioning properly. I would use WD Data Lifeguard Diagnostic tool. Here's a link: http://products.wdc.com/support/kb.ashx?id=79j0qA
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/378862-first-build-help/#findComment-5125240
