thermal glue/sticky pads
well it gets alright temps considering, for gpu and cpu, but chipset/ssd get quite hot, it's not as much for the no air flow cooling, it is for when i do gaming at home etc. with a cooling stand under it, i put a couple of those raspberry shivs on the ssd, drops temps from 80ish to 55c when it has the little fan moving air under it.
SSDs don't follow conventional wisdom regarding temperature vs life expectancy.
The above chart from Intel shows the relationship between temperature in Celsius and SSD data retention lifespan measured in weeks. Of note this chart is for drives that have already reached or exceeded their rated maximum lifetime writes, so for an Intel 730 240GB that's 91TB of host writes. (Your drive is rated for 72TB for all capacities.) A quick reading of the chart shows us that for maximum NAND longevity we actually want *higher* temperatures (to a point) while the drive is active, but lower temperatures while the drive is off.
Poking around into the Google machine we see that the M500 has a maximum rated operating temperature of 70c, so if that 80c number you're getting is from the SSD (I can't say for certain from your post) then we'll want to verify its accuracy. If you're actually seeing 80c then some variety of heatspreader on the offending chip(s) would be in order. Likely only the controller chip is seeing these elevated temperatures.
For the thermal tape you'll either want to use 3M 8810 or Akasa AK-TT12-80 if you don't want to use a more permanent thermal adhesive like Arctic Alumina's two part paste. (Despite the name it's actually nonconductive.)
