Completly depends on your hardware.
Usually 2x 140mm at the front and 1x 140 at the rear is enough.
But if you want the maximum airflow I would use 2x 140mm at the front as an intake, 1x 140mm at the rear as an intake and 3x 120s at the top as an exhaust.
You can also add another 120 at the bottom as an intake to get even more air in.
https://linustechtips.com/topic/378380-760t-cooling/#findComment-5113327
