For LoL and CS the 750ti should serve you well, but if you plan on editing on a regular basis I recommend atleast the i5 and maybe a r9 280x/960 depends on your needs though
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/377500-first-build-cpu-troubles/#findComment-5102221
I wouldn't put an AMD GPU with an i3. The drivers use more CPU in DX11 games so they will bottleneck a lot easier than Nvidia GPUs with something like an i3, Athlon, FX CPU etc.
^^^ look at the framerate drops in the second half of the video on ultra settings (more load on the CPU from the higher settings). And look at the framerate staying consistently below 60 here:
Meanwhile i3 with GTX 780 has much higher minimum framerates (still a bottleneck of course, but doesn't drop nearly as low):
Here's one showing the same CPU with the R9 280X and GTX 770 (about the same) in Battlefield 4:
Intel i5-4690K @ 3.8GHz || Gigabyte Z97X-SLI || 8GB G.Skill Ripjaws X 1600MHz || Asus GTX 760 2GB @ 1150 / 6400 || 128GB A-Data SX900 + 1TB Toshiba 7200RPM || Corsair RM650 || Fractal 3500W
https://linustechtips.com/topic/377500-first-build-cpu-troubles/#findComment-5102460
Yeah I would get the i5 and the better GPU
https://linustechtips.com/topic/377500-first-build-cpu-troubles/#findComment-5102475
That works too =)
https://linustechtips.com/topic/377500-first-build-cpu-troubles/#findComment-5102597
get a better gpu. and get an i5 4440.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
https://linustechtips.com/topic/377500-first-build-cpu-troubles/#findComment-5107738
