Fan Hubs
Go to solution Solved by hypnodog,
You could use a fan splitters or a 4 pin hub.
I found a decent 4 pin hub for around $17. (http://www.newegg.com/Product/Product.aspx?Item=N82E16811999309)
and here's a $7 fan spiltter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026
My shitty motherboard only has like one working 4 pin fan connector, I'm wondering if there is a hub of some sort that takes one connection and turns into to multiple fan connections.
I know there is fan controllers but they are expensive and too much, I don't even need to control it. Just a small board that can chill inside my case.
https://linustechtips.com/topic/377460-fan-hubs/
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/377460-fan-hubs/#findComment-5101814
