When playing heist missions, while trying to get into the car with the other player i get stuck in the door opening posture. And when i manage to get in, the vehicle keeps skiping from one place to another. whats up with that? is it because of any slowdown with my internet connection? please help.
And also is there anything i can do to avoid "timed out loading session" problem?
https://linustechtips.com/topic/376926-gta-5-online-problem-please-help/
Yeah pretty sure it's connection issues, I've had similar problem with wifi(being a bad connection), however I got ethernet to my room recently and it alleviatedall issues.
That's the problem.
Your download speed is horrific
Nope, I have less than that and it doesn't happens to me... "Horrific" seems a bit of an extreme word when even people with high bandwidth have had issues with GTA V online.
To the OP, if it only started doing that recently then it's probably server issues or/and the connection with the other players. By the way, you probably already knew it but... GTA V online is no the best out there in terms of stability.
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
