Hey guys, a few more questions:
First, I'm getting a full cover water block for a titan x, do I really need to get a back plate? Am I losing anything if I don't?
Second, I'm really stuck on what pump to get. I don't want to spend too much money on it, but at the same time, I need it to be reliable. Any recommendations?
Third, would this fan be enough for a triple 120mm rad? Are they strong enough?
Thanks!
RabidBurn
TS3 I frequent: ts.absgaming.net feel free to join!
https://linustechtips.com/topic/376911-help-with-water-cooling/
You don't HAVE to get a backplate. But what's the point in getting a sexy custom water cooling loop if you don't have a sexy backplate to put on those GPUs?
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/376911-help-with-water-cooling/#findComment-5095673
Thanks!
RabidBurn
Backplates aren't mandatory but they help with cooling any memory chips on the back and keeping the card stiff. For pump selection one of the best is the Laing D5 pump but another is great one is the DDC they do get a bit warmer and tend to not have as much flow rate but still excellent head pressure.
https://linustechtips.com/topic/376911-help-with-water-cooling/#findComment-5095709
True, looks like I might end up getting a hydro copper series anyways... :/
Okay, thanks! I'll look into those pumps!
RabidBurn
https://linustechtips.com/topic/376911-help-with-water-cooling/#findComment-5095816
Sorry, could you link me to that pump? I can't find it on any canadian websites :/
https://linustechtips.com/topic/376911-help-with-water-cooling/#findComment-5095843
If your in Canada try Dazmode they should have you covered fro everything, and here are the pumps:
https://www.dazmode.com/store/category/bare_pumps/
https://linustechtips.com/topic/376911-help-with-water-cooling/#findComment-5095856
Would these fans be alright for a triple 120mm rad?
You want to make sure they are pressure optimized fans those look like they might be they aren't very good quality especially the sleeved bearing but if you want a value solution something like Swiftech's helix fans are a good option, another is Corsair dual packs but they do cost more.
https://linustechtips.com/topic/376911-help-with-water-cooling/#findComment-5096076
