This is my first water-cooling build and I was pretty confident in myself so I went for a rigid tube build. I think it looks pretty nice and wanted to share with the rest of you! I can throw in more better quality pictures in later if requested. Enjoy! :)
Specs:
MSI z97 Krait Edition
i5 4690k
EVGA Nvidia GTX970 SC ACX2.0
HyperX Fury 8GB White
Fractal Design S
Corsair CX600M
Samsung 850 EVO 250GB
Seagate 1TB SSHD
Monitor:
Acer B286hk
Watercooling:
Primochill PETG tubing
EK Supremacy MX
EK-FC970 GTX ACX
Primochill ghost compression fittings
Koolance PMP 450 Pump
Corsair SP120 PWM Performance fans
Black Ice Nemesis L-Series 360 Rad
Bitspower Water Tank Z-Multi 250
XSPC D5 Multiport Acetal Top
post-184557-0-94847500-1433010047.jpgpost-184557-0-58049100-1433010065.jpgpost-184557-0-64746300-1433010081.jpg
https://linustechtips.com/topic/376753-first-time-liquid-cooling/
Balls that's pretty :P
And expensive ... I've always wanted to wc, but couldn't get myself to spend as much on wc as on my components :/
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
for a first timer that is amazing..
I mean look at mine.. http://imgur.com/WFY8ve7,MqQNTnQ#1 http://imgur.com/a/ngKEu/
you haven't seen mine lol
looks pretty good, but the line from the pump to the GPU needs urgent care.
the bend at the GPU is closed off and artificially creating exceptional head
pressure and will starve the system causing premature overheating (low coolant
flow). i wouldn't do any voltage overclocking till this is corrected. especially
being downline of the CPU.
would deffo recommend using a silicone insert when bending the tubing.
Yup! Was the last tube I bent and I ran out sadly. Replacing that part as soon as possible. Sadly, the silicone insert primatial provided did not fit the tubing so I had to free hand everything. :( Right now I'm using everything at stock for a bit to make sure everything is running properly before I start to overlock, but it's all working beautifully!
@JayzTwoCents ran into the same on his PETG reline, he suggests to contact
primochill about the issue (sounds like a common issue) and they may correct
the issue of out of tubing (you should have contacted them prior).
Thanks for the info! I'll definitely contact them, maybe they'll supply me with the tubing I need to fix it, too! :D
