Need help with my Note 4 URGENT!
Solved by lani100,
I need help!!!
I'm from Malaysia.
I just updated my phone to the latest lollipop update and bug fixes patch.
But after I run Antutu Benchmark.
My peformance is under the Galaxy S5.
I have tried to re-install the app.
But the result is the same.
Try a factory reset, you will lose your data doing this so make a backup first.
Is it really that urgent tho get a higher benchmark score
Featured Topics
Wubb ·
Posted in New Builds and Planning2 -
erico2304 ·
Posted in Troubleshooting0 -
aisle9 ·
Posted in Peripherals0 -
4
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
7
