hello I have a budget of around £850 I want a gaming pc ready for bf4 that is cheap and good. I don't care about noise but I do want a cool cpu I don't mind water (closed like a h60) or air. I don't really want a amd cpu I would like either a 3770k or a 4670k thats pretty much my suggestions can some one make me one of those build list as when I did my build I bought a prebuilt system when I was a newb then I moved it into another case and put a new cpu in and psu so I do know how to build and fit and I have a antistatic wristband thank you I also want a case that is not cheap hand has a bottom mounted psu and slots for fans thank you
Owner Of The Crappy .gifs
https://linustechtips.com/topic/37659-help-with-a-build/
BF4 will be optimized for AMD -> pretty sure for 6 or 8 cores. 8350 will do just fine. Cheaper than 4670k and you can add cooler to it. hyper 212 evo will not only be quiet and keep it cool, but also add overclocking headroom. and its cheaper and more reliable than h60
where are you buying parts?
https://linustechtips.com/topic/37659-help-with-a-build/#findComment-483893
http://uk.pcpartpicker.com/p/1iGiM tiny tad over your budget but this will get you the performance you want. If you don't care about PhysX and you want more FPS, I'd get 7970 instead. Oh and if you don't mind bigger system startups and loading times, you can get rid of the SSD and get a 770.
https://linustechtips.com/topic/37659-help-with-a-build/#findComment-483986
Thanks for that build list do you think that the new generation of amd fx will be am3 and would it be worth getting a custom made rather then building my own as ordering from that many companys will be hard i was thinking of dino pc ? thanks
https://linustechtips.com/topic/37659-help-with-a-build/#findComment-484066
Here you go: http://uk.pcpartpicker.com/p/1iPU9
Sli ready.
https://linustechtips.com/topic/37659-help-with-a-build/#findComment-486369
