Cable sleeving
By
Polish_Laska
in Cases and Mods
in Cases and Mods
Solved by knight_40k,
Sometimes you need to work it in a little. Remember to burn the end so it doesnt fray and then rotate it while squishing and stretching it.
Also, it might look flat, but once you get it fully on the cable, you need to hold one end and pull/strech it out over the cable and it will round up. Sorry for my bad describing, there are several videos on youtube about sleeving, search lutro0.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases4 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
