Stealthy/Tiny Audio Recorder?
Hey guys,
I've been looking for a small, good quality, indicator-less USB (not necessarily) flash drive audio recorder for my university lectures much like the ones here:
But the problem is that these Amazon ones are all cheaply made Chinese devices with low file transfer speeds and only 128kbps audio recording with zero noise cancellation whatsoever.
I was wondering if anyone knows of any better quality (presumably higher priced) recorders that double as high-speed USBs and maybe with more storage as well? If not that, then just a really small good quality audio recorder that fits on a keychain?
Thanks a lot for any help.
https://linustechtips.com/topic/375888-stealthytiny-audio-recorder/
SNIP
not small but Zoom H1 - stick it in your bag
Thanks for the suggestion, but not sure how it would be able to pick up audio from inside my bag?
I meant.. put it on the table when recording..carry it in your bag :P
i would say TASCAM DR-05 because it's competes with zoom H1.
could you use a phone?
Yeah phone is what I would normally use but it's clunky having to open an app and calls disrupting the recording + what if the phone battery dies in the middle of a 2 hour lecture, etc, etc.
So just looking for a tiny rechargeable at least 320kbps device that i can just swtich on and off manually whenever I need it to record basically.
Anyone have any other suggestions? The zoom seems good but a smaller keychain attachable one would take first priority.
I'm actually surprised that I can't find a good quality consumer mini recording device anywhere at this stage in the tech era..
Physics prevents quality and tiny going hand in hand.
