Filter questions
Go to solution Solved by 1Scotty1,
yeas
Then if it is a bigger gap, or even a smaller one, but bigger than the normal filter holes, change it :) because larger particles could slip through and we don't want dust in our PCs ;)
So I have bought a few filters, the magnetic ones and I am wondering how to clean them, do I use water, and do I leave them to dry. I have also noticed that they are gathering gaps in between the mesh. How do you guys clean your filters?
https://linustechtips.com/topic/375886-filter-questions/
Stick them under running water, dry with towel, leave to dry thoroughly on warm radiator... profit!
thanks mate, but i have seen gaps start to form, should I change the filter as in get new ones once in a long while?
https://linustechtips.com/topic/375886-filter-questions/#findComment-5083372
