Case For Water Cooling
Go to solution Solved by AJR,
Enthoo Pro - $99
Wait a minute...
I need to find a good ATX case with enough space for a custom water cooling loop, but I don't have a ton of money so I can't get anything $100+
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/375610-case-for-water-cooling/#findComment-5080030
Have you looked on eBay you could probably get a better case if you want a used one
https://linustechtips.com/topic/375610-case-for-water-cooling/#findComment-5080411
Choose the case wisely and make sure you can fit all your water cooling hardware in the case. I recently custom water cooled my CPU and GPU with a 120x3 45mm thick radiator in push/pull configuration and it just barely fit in top part of my NZXT phantom 820 (btw this case is massive). Just plan out your build and make sure everything fits. It's better to spend little bit more for something you admire than something you had to custom alter and end up as an eye sore.
https://linustechtips.com/topic/375610-case-for-water-cooling/#findComment-5081636
