I haven't worked with that case before, but there's always a way. If worse comes to worse, then you can always put some tape on the LED in the color you want.
Main Rig:  FX-8320 || EVGA 650 Ti BOOST || AsRock 970 Extreme3 || Corsair 800D || 8 Gb Crucial Ballistix || Antec HCG 520M || Noctua NH-D14
LAN Party Rig: FX-4100 || EVGA 550 Ti || ASUS M5A78L-M LX PLUS || Cooler Master 430 Elite || 4 Gb Corsair Vengeance || Antec HCG 400 || Cooler Master Gemin 2
Staples EasyTech Associate since September, 2013
https://linustechtips.com/topic/37551-define-r4-led-mod/#findComment-488702
just desolder the leds and resolder a replacement in the colour you desire.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/37551-define-r4-led-mod/#findComment-492764
