I decided to build a PC but I can only stay at the $1200 dollar price range but I would like for it to be as powerful as possible so this is what I had in mind, any suggestions, help and improvements will be greatly appreciated, Thanks in advance
CPU: i5 4690K Quad-Core 3.5Ghz (will be overclocked)
GPU: EVGA GeForce GTX 970 4GB STRIX
Motherboard: Asus Z97-A ATX LGA1150
Memory: Corsair Vengeance 16 GB DDR3-1600
SSD: Samsung 850 EVO-Series 250GB 2.5"
HDD: Toshiba 3TB 3.5" 7200 RPM
Cooler: Scythe Kotetsu 79.0 CFM
PSU: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX
Case: Fractal Design Define S w/Window ATX Mid Tower
https://linustechtips.com/topic/375157-budget-build-help/
Everything but the GPU and HDD are OK.
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074402
$1200 isn't budget build......
By the way, if you don't do much chrome tab you can save some money by going 8GB ram
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074404
A more of a 'budget build' in your case is my future build. The Pulverizer: http://pcpartpicker.com/p/qhYLLk
It's a lot of the same parts, in a black and red theme, and backs up a bit on some parts that aren't really needed.
There is also room for upgrades in the future if need be.
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074509
To much unnecessary stuff that could be cut down in price.
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074538
I'm cofused ... EVGA and STRIX ?
... Life is a game and the checkpoints are your birthday , you will face challenges where you may not get rewarded afterwords but those are the challenges that help you improve yourself . Always live for tomorrow because you may never know when your game will be over ... I'm totally not going insane in anyway , shape or form ... I just have broken English and an open mind ...
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074592
Maybe some stuff could be cut but I wouldn't do it. From this build it's the best you can get to run games, is not too expensive, and has room for upgrades.
A Z97 motherboard and a locked processor bitch please that a rookie mistake.
 Same here
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074625
And changing it would add on money not subtract it. You don't have to be so med
man it aint a dick dont take it so hard
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074658
So basically a cheaper case, a little better cpu, and only a couple bucks cheaper. Mmk
You forgot Its liquid cooled, It Can Overclock until it kicks the shit out of a i5-4460, and has the Absolute Best 970 that Overclocks Like A Fucking Monster, and a better PSU to fuel it.
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074736
No I didn't forget it's liquid cooled. The one I had was just fine. It doesn't 100% need a liquid cooled. The 4460 doesn't fall too far behind the 4690k except for overclocking. A 600W would do just fine but if you want to add future upgrades a extra 50 W will kind of help but you'd need more to support any major upgrades.
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074778
Its obvious you have never seen the amount of power a 4690K and a G1 gaming 970 can draw when overclocked to balls, also the low end corsair PSU's are far from being the best when it comes to not killing themselves.
And yes a 4460 wont fall behind until you turn up the multiplier on a 4690K then it sacks the 4460 steals its money and screws it's girlfriend.
https://linustechtips.com/topic/375157-budget-build-help/#findComment-5074803
