Im planning to build a pc and i want to know if its good or not, ill be using it for gaming and photoshop, after effects etc.
Cpu : i5 4460
Motherboard : Asus H97M-E
Storage : Western digital 1TB 3.5" Blue HDD
Memory : Kingston HyperX Blu 16gb (2x8gb)
Gpu : GTX 960
Psu : Corsair VS550 ? / Antec VP550P ? / Cooler master GX550 ?
https://linustechtips.com/topic/374541-how-is-my-first-build/
Cpu : i5 4460
Gpu : GTX 960
I'd suggest changing the processor to a Xeon 1231 V3 since you get the 8 threads which will do wonders for render times. - This is under the assumption that you're doing a reasonable amount of rendering.
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5066096
Budget? Where do you live? And use PCPartpicker for all your builds.
For what you have now, you will not be able to OC whatsoever, or have a multi-card setup.
Will you being doing HEAVY video editing? If so, get an i7, as it'll really help. If it's lighter editing, it should be fine. If you have the money, really check out my build, pretty goddamn awesome:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($87.49 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($112.99 @ SuperBiiz)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($99.98 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($319.99 @ SuperBiiz)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  ($39.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($86.98 @ OutletPC)
Other: RGB Lights ($20.00)
Total: $1366.73
Generated by PCPartPicker 2015-05-26 22:18 EDT-0400
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5066103
Cpu : i5 4460
Gpu : GTX 960
Hey opsardo110398,
The build looks good and should meet your requirements.
I would consider adding a SSD to the build as it should boost your overall computer performance, make it much more responsive and decrease all loading times and boot times.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5067786
Wouldn't a Z97 board be better for unlocked processors over an H97?
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5068631
http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
Excellent PSU for the price, better than the Corsair CX suggested, and is MUCH better than the VS which is even worse than the CX!
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5068944
Z97=overclocking
H97=no overclocking
Wouldn't it be better to get a Z97 board then?
At least there's the option of overclocking later on if you upgrade to an unlocked processor (which, frankly, most of us do).
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5070744
The Z97 motherboard would enable you to overclock CPUs and to use multiple GPUs. Other than that you shouldn't notice differences. You should also have an unlocked CPU in order to overclock it and a custom CPU Cooler. It's up to you if you'd like to do it or not. :)
Captain_WD.
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5075383
Captain_WD.
You can also make use of 1600Mhz+ speed RAM, whereas H and B series are limited to 1600
There's no reason to not get one, as as @TheCaptain53 said if you upgrade in the future, the option to overclock freely is there
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5075389
True :) It all depends on what you want from your build and if you ever plan to overclock.
Captain_WD.
https://linustechtips.com/topic/374541-how-is-my-first-build/#findComment-5075414
