Network help
Go to solution Solved by KTFO|SGTmoody,
How do I enable it?
You dont need to, Its fine, you can connect to the internet, sometimes you find windows doesnt update the icon, Probably if you just logged of and logged back on again the Icon would be normal.
Hi,
My PC says it isn't connect to the internet (has a big cross through the icon) but I am connected.
I am using Windows 7 and wired network.
Thanks to anyone that can help,
- Meme
Press Ctral + R  type CMD  press enter,    black box opens,  type: ping 8.8.8.8
Tell me if you get a "reply from 8.8.8.8"
https://linustechtips.com/topic/374067-network-help/#findComment-5059881
big cross on the network can mean the LAN port is not enabled
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/374067-network-help/#findComment-5059888
right click on the network sign and click troubleshoot problems
also check your device manager and check if the port is enabled
it seems your network is fine since it can ping the google server
look elsewhere
check if you can surf the web now
https://linustechtips.com/topic/374067-network-help/#findComment-5059909
