Help me pick a GPU
Go to solution Solved by TechFan@ic,
The HD 7950 is your best bet, it consumes significantly less power than the GTX 760, it's got 3GB of VRAM as opposed to 2GB on the 760, it overclocks significantly better and you get better anti aliasing performance.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026
It has 3GB of VRAM on a 384bit interface instead of 2GB on a 256bit interface which gives it a very sharp edge even over the 670 which is more powerful than the 760.
Anti aliasing is the graphics setting that removes jagged edges.
http://www.tomshardware.com/reviews/geforce-gtx-660-ti-memory-bandwidth-anti-aliasing,3283-13.html
I'm sorry if I post to the wrong section.
I want to buy a new GPU, and I have no experience about GPU. I need help, please help me.
My budget $300
Priority : low power consumption, low temperature, performance, stable (last long :D).
I don't care which brand it is.
Thanks a lot!
https://linustechtips.com/topic/37357-help-me-pick-a-gpu/
7950: http://pcpartpicker.com/part/sapphire-video-card-1003523l
Not sure what you mean by low power consumption though.
What are the rest of your system's specs?
https://linustechtips.com/topic/37357-help-me-pick-a-gpu/#findComment-480293
heya,
My budget $300
If you want a low power and low temp GPU, I would recommend the nVidia gtx 760. In that price range, it would be the best bang for buck, money  ^_^
7950 would be  great competitor, but the heat output will be a little higher than the 760. The acoustics will be a little higher than the 760, also.
Hope this helps,
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/37357-help-me-pick-a-gpu/#findComment-480306
https://linustechtips.com/topic/37357-help-me-pick-a-gpu/#findComment-480322
gtx 680 used $320 worth to buy?
If it's the 4GB version then yes, if it's the 2GB version then no, 2GB won't last you long enough, the XBOX allocates 5GB of the 8 GB of VRAM only for the GPU and the PS4 allocates even more, so GPU memory requirements will go dramatically up within the next year.
https://linustechtips.com/topic/37357-help-me-pick-a-gpu/#findComment-481559
