Hey guys, is it possible to have raid 10 with  3 drives ...
what i actually want to know is if i can have 2 SSDs in RAID 0 and 1 HDD that they will be backed up to ..
do i need a raid card ?? ( i dont know anything about raid cards and what to do )
https://linustechtips.com/topic/373431-raid-help/
No, RAID 10 requires at least four drives.
No, you're better off using a software that will automatically copy the SSDs in RAID0 to the hard drive. RAID 10 with one span of SSDs and one span of HDDs will result in reduced speeds because it will be bottlenecked by the hard drive. It's also recommended to use all of the same drives in any RAID.
No, you don't need a RAID card / shouldn't use one in this situation.
https://linustechtips.com/topic/373431-raid-help/#findComment-5051963
