Hi, I'm looking to buy a 3D printer for personal use. I have some experience in using one, but zero experience in buying one. I'm currently looking at an Asterid 2000 from Plastic Scribbler for $500. It uses 1.75mm non-proprietary PLA filaments and has a build volume of 8x8x9.5 inch.
Can anyone suggest a better 3D printer for a similar price? I would like to keep within this price range but would not mind a more expensive printer if additional features justify the cost.
some criteria on the printer:
  • must use non-proprietry filament
  • preferably uses standard 1.75mm filaments
  • preferably able to use more than one kind of filament
  • decent build volume
also please list any necessary additional software (besides a CAD program) with your printer recommendation.
Thank you!!
https://linustechtips.com/topic/373292-3d-printer-recommendation/
The solidoodle 4 and press are around that price range and are supposed to be very good. They just raised the price on the 4 by $100, but the press is basically the same as far as I can tell. http://www.solidoodle.com/
Another option would be the printrbot simple metal. http://printrbot.com/shop/assembled-simple-metal/
Good luck!
ASU
