how does this work then?
Go to solution Solved by dragoon20005,
but it was all ready overclocked
since your current GPU temps still have a gap between the max temps
it will still try to crank up the speed before it hit the thermal limit
so i have my power limit set to 110 (MAX) in after burner but after playing GTA for a bit i noticed that the GPU hit 114% power why is this it should only go to 110% right?
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/373119-how-does-this-work-then/
Geforce Turbo boost
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/373119-how-does-this-work-then/#findComment-5048255
it was running cool enough so GPU boost boosted it? I don't really know...
i guess max temp was 70c and target temp was 79c and this happened after i prioritized power limit because i use to worry about temp so i had that prioritized
PC PART PICKER
https://linustechtips.com/topic/373119-how-does-this-work-then/#findComment-5048257
https://linustechtips.com/topic/373119-how-does-this-work-then/#findComment-5048268
cool thanks for that. also
fc3646a02beca4bbf6c05e711f81c0eb354d2531
PC PART PICKER
https://linustechtips.com/topic/373119-how-does-this-work-then/#findComment-5048286
POWER!!!
damn i missing Clarkson already
https://linustechtips.com/topic/373119-how-does-this-work-then/#findComment-5048291
