My GT 640 is having problems. I know that it's outdated but it used to work way better.The games it used to run at 60fps now only run at 30 or below. Every now and then it will go back to the frame rate it used to run at and stay there for a while but then drops back down. It's like something inside isn't working correctly. I've tried restarting but that doesn't fix it. It's not something with temps either, it stays around 30 to 50 Celsius. Also not a cpu bottle neck. I may have to buy I new card in the future. We have had a power outage recently that may have effect it but it still works just not like before.
https://linustechtips.com/topic/372995-gpu-performance-problem/
maybe take the card out and clean out the cooler, there might be some overheating vrms
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/372995-gpu-performance-problem/#findComment-5046916
what games do you play and at what settings ?
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/372995-gpu-performance-problem/#findComment-5046943
Cooler cleaning and thermal paste change maybe needed
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/372995-gpu-performance-problem/#findComment-5046967
