So i connected LCDTV to my pc with hdmi  and its a little bit blurry idk why ;/ i tryed some other rezoliutions and its the same problem ;/
Heya,
When images look "blurry", it is usually because the pixels aren't changing quick enough. TVs are prone to this are they are not produced for the purpose of high frame rates. You will experience this blurry picture, no matter what resolution you use.
A different display would be your best solution  ^_^
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
