If your gaming this
http://pcpartpicker.com/p/xH9JD3
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041459
Is this for gaming or productivity? Budget total? I need more to work with here.
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041460
If your gaming this
^^ this
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041462
Why the blower 970??
First one I saw on GPU list.
sex hahaha
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041479
My bad, its is for gaming recording and video production. I just need something to get me off the ground because i have a gateway computer with complete crap inside.
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041481
Go with this:
http://pcpartpicker.com/p/Pttgyc
And add a ssd and a cpu cooler later
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041498
The stock cooler would do just fine?
I was way off budget look at my edited post above as it os closest and yes the stock cooler is fine for this build
It is also here: http://pcpartpicker.com/p/Pttgyc
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041526
awesome, so i could game and record off of this as well as edit videos?
You could game and probably record decently for 1080p on most games with this system however your price won't let me say you will be able to play and record every game with this build
https://linustechtips.com/topic/372515-low-budget-build/#findComment-5041565
