Hello there,
A group of my friends and I are doing a school project about recreating paint in Java. I wanted to add something unique so i decided that i'll a add the possibility to draw a circle that, given three points, touches them. Like so :
I am encountering some problems, not from a logical point of view but when I need to "translate" math language into Java i don't now where to start.
Here's what I would do in math:
  • Find the equation of the line that passes between A and B with the formula c12477cdfdc018efb1fc22307619afbb.gif
  • Do the same for the line that passes between B and C using the same formula
  • Find the "middle point" (I don't know if the term is correct) of AB and BC using the formula be91ccc6a451c4150f75d75ff56759ca.gif
  • I have the m of the equation y = mx +q so I can just obtain the m of the axis by doing the anti reciprocal of the m of the lines that passes between A and B, B and C
  • Obtain the equation of the lines that passes between the middle point (axis) of AB and BC, knowing m using bf5f9a7890045c8192261320506420cf.gif
  • Do a system between the equation of the two axis and find the center of the circle
  • Draw a circle
I only know that for resolving the system it is more convenient to use Cramer's method   but that's the only thing I know.
Any help will be appreciated. If something is not clear feel free to ask, especially if you don't understand something due to linguistic unclarity because I am not an English native speaker. Thanks
https://linustechtips.com/topic/372049-java-and-analytic-geometry/
you need to find the generic equation of the generic circle that passes through three generic points
the equation of a circle is in the form
(x - a)^2 + (y - b)^2 = r^2
so you need to find the three functions f, g, h so that given three points P1, P2, P3
a = f(P1, P2, P3)b = g(P1, P2, P3)r = h(P1, P2, P3)
at this point it's just a math problem
i think that a simpler approach to the problem is to only use the generic equation of a circumference instead of making segments, intersecting them and stuff.
you can insert the coordinates of each of the three points into the equation of the circumference, so that you get a linear system of 3 equations (one for each point) in 3 variables (a, b, r) and you only need to solve that
Yeah, you're right. Your method is much more simpler than mine.
Now the big question. How do i resolve three-way system in java ? Cramer's method ?
it's much more simple than that: you need to work out the generic formula by hand, and you will end up with a formula that you can write down in java as a simple expression
so you have three points with generic coordinates:
P1(a, b )
P2(c, d)
P3(e, f)
plug those coordinates in the system and solve it using your favorite method
