Bi Color Led Indicator Mod?
Go to solution Solved by W-L,
And how would I get these to work my Motherboard?
I would check with a multimeter first to see if it's the reverse polarity, which I believe it should be since I haven't seen a motherboard with two positive lines for a power LED.
As for doing the replacement that's fairly straight forward, getting a similar or same LED and replacing the one you have in place with some soldering.
Hello! I have the Corsair 300R, and my Power Led Indicator blinks in sleep. Its super annoying. So I went into BIOS and changed it to Dual Color Mode. It disabled the sleep blink because my case doesn't have an extra LED. Just curious, could I make a mod for this? How much would a BiColor Led Power Indicator cost, and is it easy to do? Thanks for any help.
My PC/ CPU: Intel i5-4690k with ColerMaster Hyper Evo 212 / Motherboard: Asus Z97-AR GPU: EVGA GeForce GTX 750 Ti / OS: Windows8.1 / RAM: G.Skill Ares Series 2x4 1600Mhz / Storage: Seagate Barracuda 1TB 7200RPM Optical Drive: ASUS 24B1ST / Network: TP-Link WN881ND /////////////////////////// If I fail to respond to your questions, please message me! Thank you
https://linustechtips.com/topic/371829-bi-color-led-indicator-mod/
They aren't very expensive but usually come in large packs, you can maybe find some individual ones from electronics places.
There are two kinds of bi-color or dual color LED's, ones that have 3 leads, one common Grd wire and two positive lines for each color and a 2 lead version where you have to reverse polarity which I assume is what is on the motherboard.
3 Lead LED:
http://www.amazon.com/Common-Cathode-Green-Light-Emitting/dp/B00NQ6RU9O/ref=pd_sim_sbs_328_5?ie=UTF8&refRID=0JDMZKCK1FGTEPDNF54E
Reverse Polarity:
http://www.instructables.com/id/The-RedGreen-LED-Guide/
3 Lead LED:
Reverse Polarity:
Ok Thanks!
dumb question.
