So it's finally time to begin my build log. Moments ago, I ordered my final PC components, which should be due for arrival in about 4 days, so I figure start with what I have. Seeing how I don't quite have all my parts yet, I will have to go back and add to posts to update the log and what not, but the overall topic should be very cleaning looking in the end, once all the blank spots are filled in. Also, seeing how this is my FIRST build, I will also be including my peripherals just because they are a major part of the overall build. Would love some feedback, and to hear what you guys think of the build. It was originally planned to be budgeted quite frugally, but as many a build goes, it escalated when I decided to settle for nothing but top notch components. Thanks for reading guys, here's the build:
https://linustechtips.com/topic/3718-first-gaming-build/
Components:
I'll start by naming off the entire builds components, than talking briefly about each one and why I choose that specific part.
CPU: Intel core I5-3570k
Motherboard: ASUS Maximus V Formula
Graphics Card: EVGA GTX 670FTW Signature 2
Case: Coolermaster HAF 922
PSU: Corsair GS800
RAM: Corsair Vengeance 8gb (4x2)
Harddrive: Seagate Barracuda 1tb
Disk Drive: ASUS DRW
Fans: x2 Aerocool Sharks 120mm
x1 Aerocool Shark 140mm
CPU Cooler: Corsair H80i
https://linustechtips.com/topic/3718-first-gaming-build/#findComment-46026
Peripherals:
Just like the components, I'll name off what is being used, than go more in depth afterwards for my reasoning
Monitor: Acer GD235HZBID Black/Orange 2ms 120Hz 3D Monitor
Keyboard: CM Storm Trigger w/ Cherry MX Black Switches
Mouse: Cyborg R.A.T. 7
Headset: ASUS Vulcan Pro w/ ANC Noise Cancellation
https://linustechtips.com/topic/3718-first-gaming-build/#findComment-46027
Pics of the PC.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/3718-first-gaming-build/#findComment-46160
The 120mm fans I bought for the cases top vent would be limited light wise to illuminate the inside, or the outside if I used a radiator, and aesthetics was a big part for me. And in all honesty, I won't be overclocking very hard on my cpu, so I couldn't justify an H100i, an H80i does just the trick for me both performance wise, and while maintaing an aesthetically beautiful machine:]
https://linustechtips.com/topic/3718-first-gaming-build/#findComment-46270
