Fraps help?
Go to solution Solved by KillerBeel1,
I'm posting this on a different forum since I couldn't get any help the last time; hopefully I'm posting on the right spot, because I seem to post on the wrong side of the forum quite often.
Now, let me start off by saying I've had this issue for at least a month. It all started with with Fraps telling me it was a corrupt install after having used it on this pc for at least a year; I opted to reinstall the program to see if that would fix it. It didn't. So, I looked around and I found out that I could just mess around in the registry and do a clean install of the program, I reinstalled and it worked just fine. But then when I try to import my Fraps videos into Sony Vegas, I get an error telling me it's unable to import. A couple days ago I downloaded Virtual Dub to try to convert the clips and I get an error saying "Couldn't locate decompressor for format FPS1 (unknown)."
I think I might have deleted that when I removed some registry keys. But I'm not too sure, if anyone could help me; that would be awesome! :D
https://linustechtips.com/topic/371212-fraps-help/
Use Handbreak instead of whatever converter crap you used.
Also, are FRAPS and SV pirated? I know there was an issue with a SV crack a while back that would corrupt project files after a they got to a certain size.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/371212-fraps-help/#findComment-5033555
Handbreak makes it look terrible though t-t, I wanted to keep the raw file instead of converting anything. Also; both Fraps and SV are pirated, I'm not paying no 600$ for both programs. Also, I did re-install both programs and used different versions, it hasn't done anything to fix my issue. Oh, and I think you misunderstood my issue, I can't convert anything because the decompressor isn't there.
https://linustechtips.com/topic/371212-fraps-help/#findComment-5041697
I agree that SV is not worth the money.
It's just not powerful enough of a tool to be worth that much.
Can you screenshot your project template for me? as well as preferences in sony vegas.
https://linustechtips.com/topic/371212-fraps-help/#findComment-5042314
 Here you go, I wasn't too sure what tab you wanted me to screen shot exactly, but here you go :PxI8e3FG.png6e54HQm.png
Un tick the "Adjust source media to better match the project or render settings".
Also un tick "Close media files when not the active application" and "Close audio and MIDI ports when not the active application.".
I would also suggest doing this.
If this does not work, i would say go down to Sony Vegas 12, because I had other problems with 13 and just gave up and went back to 12.
https://linustechtips.com/topic/371212-fraps-help/#findComment-5047430
Well the last time I used obs the video quality was terrible. That's why.
You have to dink around in the settings and manually set the quality settings.
IMHO I don't like either, I just use shadowplay.
https://linustechtips.com/topic/371212-fraps-help/#findComment-5054419
 Never mind! I fixed it by installing a avi plugin ;D thanks TDP_Equinox for your help though.
Glad you got it fixed!
Mark the topic as solved so others with this issue can find the solution faster!
P.S
Maybe post a link to the plugin as well.
https://linustechtips.com/topic/371212-fraps-help/#findComment-5056942
