I am looking into building a new computer for everyday use and for moderate gaming. I want to purchase the bare necessities for now to keep the cost as low as possible. I am going to add later (in this order), WD Blue, Corsair H100i, GTX 970. I want this system to run quiet so the case was a no-brainer. I need the DVD drive. Is there anything you would change about this build without making it any more expensive?
http://pcpartpicker.com/p/g2Mzxr
https://linustechtips.com/topic/371209-first-sub-800-build/
Don't use that SSD, get something like a FURY SSD:
http://pcpartpicker.com/part/kingston-internal-hard-drive-shfs37a120g
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/371209-first-sub-800-build/#findComment-5025761
http://pcpartpicker.com/p/DWKPD3
*shh (just pirate windows)
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/371209-first-sub-800-build/#findComment-5025763
$775
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard  ($97.98 @ Newegg)  <<<SLI, with a decent power delivery to the CPU... not extremely important for Intel CPUs though.
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($52.99 @ Newegg)
Storage: A-Data Premier Pro SP920 256GB 2.5" Solid State Drive  ($89.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon) <<<Has a 6 fan, fan hub controller for quiet operation of the case fans through a single PWM socket on the motherboard.
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($71.98 @ Newegg) <<<High quality Seasonic PSU
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($12.99 @ Newegg)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  ($83.70 @ SuperBiiz)
Total: $729.61
Generated by PCPartPicker 2015-05-21 21:19 EDT-0400
https://linustechtips.com/topic/371209-first-sub-800-build/#findComment-5025797
Is there any specific GTX 960 you recommend?
I would highly recommend one from EVGA and definitely a 4GB version.  The FTW would be my top choice, with the SSC version as second.
FTW:  http://www.newegg.com/Product/Product.aspx?Item=N82E16814487132&cm_re=EVGA_GTX_960-_-14-487-132-_-Product
SSC:  http://www.newegg.com/Product/Product.aspx?Item=N82E16814487128&cm_re=EVGA_GTX_960-_-14-487-128-_-Product
CPU: Intel i7 5930K MOBO: ASUS X99 Deluxe w/USB 3.1 GPUs: 2 EVGA GTX 780Ti Classifieds in SLI CPU-COOLER: Corsair H100i GTX in push/pull w/Corsair SP120 White LED Fans | RAM: EVGA SSC 16GB (4 x 4GB) DDR4 2800MHz PSU: Corsair AX1200 CASE: Corsair 780T White MONITORs: Dell UP2414Q 24" 4K and ASUS VE247 24" 1080p HDD & SDD: 2 x 256GB Samsung 850 PROs in Raid 0, Crucial M500 960GB SSD, and Toshiba 3TB 7,200rpm 64MB Cache HDD Optical Drives: Samsung 14x Blu-ray Player and ASUS 24x DVD-R/RW
https://linustechtips.com/topic/371209-first-sub-800-build/#findComment-5026276
